Lock Screen Help
chuckawd
557
I downloaded and installed the new version of FoxFi and it forced me to have a pin lock on the screen. Now, since I installed FoxFi, my phone has been freezing and running like garbage. It has been uninstalled.
So, my hope was that I could then change my lock screen back to the standard swiping but I can't because, it says "turned off by administrator, encryption policy, or credential storage" under all lock screen options except for PIN. The only option I can do for my lock screen is a PIN number and I hate it. Can anyone help me get this back to normal?
Sent from my SCH-I605 using Tapatalk
Go info your security settings and check the device administrators section....make sure FoxFi isn't still checked as one. Uninstalling should have resolved that, but it's worth a look. If that doesn't work, try contacting them directly...I'm sure you're not the first to run into this.
FoxFi is no longer listed in the device administrator section. And I still can't change my lock screen. I'm going to have to contact them and see what the heck they did to mess up my phone.
tuananh3105
