Lock Screen Pin Code Problem
juwster
79
I set up a pin code and now I do not want it. I go to Settings, Security, Pin Code, then enter my Pin Code, The lock screen option and the no lock screen option are both greyed out. They are not highlighted therefore I can not tick off No Lock Screen. Pattern, Pin, and Password are all still highlighted.
Is there any option to correct this problem other than a complete hard reset? I have already had to hard reset two times in the last 4 days due to other issues.
Most people with the same problem managed to fix it clearing credentials in the security settings. You could try that.
Thank you! That worked. After hours of searching for a solution you solved it for me.
I have a similar problem with my Galaxy Tab. Not sure how it "forgot" the password that I entered but it will not accept my password (the first time in a device that I set up a password, I always use the same one so it is not a case of forgetting it). I have tried devicemanager but it tells me that I already have it locked so reset fails. I do not wish to hard reset the device.
Aruz530
