Lock Screen Replacement
Maria Esponoza
47
Anyone know if its possible to download after-market lock screens? I am wanting to get rid of my stock Galaxy S4 one, and get something better.
Thanks!
Maria
Do you just want to change the widget that is displayed or do you want to change how the lock screen operates?
If you just want to change the widget then there are tons of options. Just swipe to the right on the lock screen until you see a big "plus" sign. Tap it and you can see what options you have for lock screen widgets. There are lots of other options in the Play store for widgets that will work on the lock screen. Dash Clock is one of my favorites.
If you want to add a lot of customization options, then WidgetLocker is an app that allows you to change a lot about how the lock screen works. It's a couple bucks but probably worth it if you like being able to customize your phone.
lencaiboncai178
