Lock screen widgets? ICE emergency numbers?
poconojoe57
Active member
Dec 10, 2011
31
Upgraded to ics. How do I get widgets onto the lock screen? I thought we were supposed to be able to access the camera or other apps from the lock screen. And how do I add additional emergency numbers to the lock screen? The thing they call ICE.
Look under groups in your contacts and look for ICE emergency contacts. Up date this to the numbers that you want someone to call. If your phone is found by someone they will be able to call who ever you have listed there. It takes a little while for it to update this.
Sent from my SAMSUNG-SGH-I727 using Android Central Forums
Thanks for the reply. I tried what you said and there is nothing titled ice in the contacts group. At least, not on my phone!
Have you up graded your phone to the new ice cream sandwich update? Here is a screen shot of mine.
Reactions: PrissyPJ
It's not there!
If I could figure out how to post a screenshot I would show you. the screenshot is dim in the clipboard, so I can't select it.
Before ics, when I captured a screen, it went into a gallery folder called ScreenCapture. Now it goes into a gallery folder called screenshots.
It's the 'Contacts' (orange) icon ... not the telephone icon.
It's not there!
Go to the phone icon
Click on Contacts
Your new screen will read Phone Groups Contacts Favourites
Click on Groups
ICE is the first option under Integrated Groups
It does not sound like you got the full up grade to ice cream sandwich.you may try to reload it.
:-0 How do I do that? Just try to upgrade it again?
I don't know for sure. I have never had to do that.
Thank you. I didn't know how to add numbers to ICE. Seemed so complicated but once I went through the steps shown here it worked just fine. I added 2 contacts to my ICE and they show up when you drag the red cross on the lock screen.
OK, I did the factory reset and it fixed my problems. I now have the ICE choice in the groups menu. Screen capture storage is fine now too. I was even having trouble with backing up with Kies. It would freeze, saying it was pairing even after leaving it for hours. Now it backs up in like 10 seconds!
The easy way to do it....
go in to contacts
go in to groups
add group
type 'ICE' as group name
add contact details now or later( doesn't matter)
select 'done'
you should now see that you have a new group called ICE-emergency contacts
when you are on the key lock screen, select emergency numbers
select the symbol of a person with an emergency light
your contacts should now be displayed B-)
go in to contacts
go in to groups
add group
select 'done'
I tried this without joy. For some reason, after adding an ICE group, it doesn't show up. Not sure why.
It is there, since if I try and add it again, it says that the "Group name already in use". :(
A
EDIT Although it initially didn't show up in my Groups from the Contact page of one of my contacts, I was able to find it on the Groups page. After adding a contact to that group there, it showed up on in the initial place I looked.
suuu
