lollipop 5.1.1
Just a question what's new on 5.1.1 I'm still on 5.0.2
Yes, I do understand how Android works, but thank you for explaining. Manufacturers can push updates for their Lollipop devices whenever they like. There does not have to be a major Android OS update for them to fix something. LG did it over the past few weeks for multiple carriers with the G4, as did Samsung for Verizon users last week. They can send out patches and such (it just needs to be approved by the carrier).
So that's why a fix could come before Android M. It's Samsung’s problem, not Google's. Rumor is right now the fix could come with the release of the Note 5 (sorry, meant Galaxy S6 edge plus) and in my opinion that's a little too long for them to patch such a big issue.
Rumor: RAW support and TouchWiz RAM fix to debut on the Galaxy S6 edge Plus? - SamMobile
Sent from my SM-G920V using Tapatalk
Major updates and even smaller ones take way too long for carrier devices that are not stock Android.
Well that we definitely agree on! Hopefully this year's Nexus won't be huge and then we can all get quick updates.
I have been itching to try a Nexus device but my first introduction to Android was the GS3 coming from RIM devices.
Ah yes, the good ol' Blackberry days. I left my Storm 2 for the OG Droid.
Still 5.0.2 on TescoMobile, which is a VMNO using O2's network.
Which is quite annoying as its absolutely stock, with nothing carrier specific.
I'm on 5.1.1 and I'm on a GS6 on O2 UK. I wasn't getting any notification of an OTA update for my phone, but as soon as I connected to Smart Switch on my laptop it told me there was an update available. Maybe try and update through your PC if you're in the UK. My model number is SM-G920-F.
Sent from my SM-G920F using Tapatalk
Finally received lollipop 5.1.1 update G920FXXU2BOFJ in UK on galaxy s6 on Giffgaff.
Is it best to do factory reset after install ?.
Always a good idea to FDR after a big update.
Not the place to ask as there is a specific Tab 4 forum here on Android Central. Short answer it is coming.
Only issue I have with 5.1.1, so far, is it f9cked up my logitech pro bluetooth keyboard I use with my 12.2 note pro. That's a mouth full. It connects, but doesn't type. Hope they fix this soon. Hear it's a Logitech only issue.
Try clearing the cache partition and see if that helps.
Is doing a factory reset necessary? Also if so, won't that get rid of all the stuff on my phone? Apps, pictures etc...
5.1.1 works super well in nexus 4, the kitkat and 5.0 was having a headphone issue handling the calls. when you plug it off, the calls appears to be in speaker but are not, fortunately google fixed that.
Thanks.
I did a factory reset after installing lollipop 5.1.1 now it runs as smooth as silk no lag or freezing with streaming at all.
tvgal
