Lollipop 5.1 + StageFright: Verizon Moto X XT1060 (222.26.7.ghost_verizon.Verizon.en.US)
Re: Lollipop 5.1 + StageFright: Verizon Moto X XT1060 ( 222.21.39.ghost_verizon.Verizon.en.USvzw)
here it the APK for our phones RUNNING 5.1.1!! Do not install this for 4.4.4.
Google Play services 8.1.15 (2250156-238) APK Download - APKMirror
Are you sure about that version number?
First, Moto X 2013 is running 5.1 not 5.1.1
Second, Shouldn't the Google Play services end in 6 not 8 ?
Just making sure I force the correct update,
Tom
Okay... Mine updated at some point to Google Play services 8.1.15 (2250156-236)
I guess it's time to side load Android Pay again.
Tom
Yes, this worked for me. 248 did not.
Advice to you people now just getting 5.1...
1. Without a doubt do a factory reset. Lollipop restores all apps and their location on the home screen, wifi networks setup, etc
2. Turn on dev options and change all animation speeds (theres 3 i think) from 1.0 to 0.5
When I switched the animation speed to .5, it was slow as molasses. However, my phone the 2 days prior today has been slow as molasses.
And speaking of my phone, sometime yesterday afternoon, its started working fine. Before, it would tell me that even at 90%, in 4 hours, it be at zero. The phone was slow, apps opened after a delay, couldn't open my email (exchange), would freeze up frequently, app installs/updates would hang, txt message went out hours after I hit send, and I couldnt' get anyone's handout texts.. I got into work late yesterday, and my phone was was about 18%, so I left it charging at work. Concerned I was about to have to do a FR, and tried to connect it to my PC (installed Moto's drivers) and the thing wouldn't connect. So the main thing I was concerned about was the data from 1 game (the others Id on't care much about.) so i had to install a chat app, which logging in would save my data to the cloud. My pictures are already set to go to Google Photos, and I would screen cap all my menus and homepages and settings just in case. So the install of the chat app was the only thing I did different all day other than in the AM, reboot after a freeze and left it charged in the plug to optimize (3rd time in 2 days though).
Then after i got home, i plugged it back in again, because it was going low (down to 30% from 70% when I left work and got home, and not doing anything from work to home with it.). Had to go out to take the kids to an activity, and so in the car i played some games. Noticed the battery wasn't draining as quickly. in fact, in the 2 hours I was there, it went from 87% to 78% with 1 hour playing and the rest just uncharged on the seat. The phone was snappy, even my email popped up. Kept playing with it at home, and it went down to about 30%, and i charged it back again. took it off for about 2 hours and it didn't drain.
This morning, checked it out, and its been off the charger since 7 am, and its only at 70%. States I have 10 hrs left. far cry from the last few days where it was always 4-5 hrs at 90%.
I dont' know what happened, but i think like all tech around me, I threaten it with something and it acts right. It probably knew I was serious about wiping it, so it got off its hissy fit and started working.
Okay I just got the update and so far so good but for the life of me I cannot figure out how to disable the haptic feedback on the lockscreen. Can anyone tell me how to do this? Thanks
Open the Moto app. Click the Settings (gear) icon in the upper right. Choose Display. Uncheck "Vibrate on touch"
I think this is the same for me. I think that what is happening is that people's Google Play Services are getting updated to 8.1.15 in the background and when that completes most, if not all, issues with the update go away.
Just reiterating what a few others have mentioned, definitely do a factory reset after updating to 5.1. Tried both ways (with/without reset) and the results are staggering. I've had my phone unplugged since 12:00 am last night and now it's just after 12:00 pm and I am at 88% battery remaining. Also, Android Pay is now working without having to download an APK and chrome now has the beautiful colors at the top of the page. Wouldn't have seen any of this hadn't I done the reset. Until a smaller form factor phone (running stock android) comes out this has breathed a lot of life into this now "classic" Android phone.
but see, that is weird, because it updated the 1st day. took its dear sweet time because it kept freezing and hanging at 11.66mb, but eventually it did. Then the errors went away for a time that first day, then came back. After one reboot and charge, i had like 8 or so error notifications, from Google Hangouts, Play, etc... everything had an issue. I kept clearing the cache and nothing changed.
Its working now fine, just put it to charge and it was at 38%. so close to 7-7.5 hrs of some use. Last night I also went and unchecked a number of non-needed apps to display on teh active display. but that was after it started to work better.
eitehr way, I think i'm happy. Oh, I also (but during the day yesterday) told 74 apps to update. usually I do selective apps. this time I did them all. can't pinpoint any one solution, but something worked.
I updated with only a few hiccups initially. Reboots cured the play services update issue and all seemed well. Battery life hasn't seemed to be any worse than before. Now, though, I can't figure out how to configure the settings on the phone to get ambient display to operate like it did previously. I've tried flipping back and forth between ambient display and moto display but no joy. Anybody have any insight?
I've done an FR after upgrade but bam_dmux_wakelock still appears to eat up the battery. I wonder if I need to do a second FR to get the results you are seeing.
OK, found a couple things I don't like.....
With a BT headset connected, "OK Google Now" is routed to the headset. I've checked for all options on this and can't find where this can be turned off. I don't want to route this through the headset, I only wear it when I'm actually talking to someone but it's connected to my phone from the time I leave the house until sometime in the evening.
Yep, I have this same issue. It's annoying and effectively kills me using Moto Voice since I'm not going to manually turn off BT or disconnect the device every time I want to say 'OK Google Now'. The other annoying side of this is if you look at the specific BT device, tap the gear icon to look at its settings, it gives you the option to un-check 'Phone audio', which is what I suspect is causing the issue, but when you do that, it simply disconnects the whole BT device. If you then manually tap the BT device to reconnect it, it automatically re-enables 'Phone audio'. So, back to square one.... ugh!
I also dislike that they 'fixed the bug' that allowed wave to wake to work.
Edit - 9/23 - For anyone else having this issue. What I found to be a solution was to check the option in Moto Voice settings for 'Audio Troubleshooting - Select if bluetooth or car audio readout is inconsistent'. I didn't think to check this before because I wasn't thinking of this issue as a bluetooth readout issue, but it worked nonetheless.
What behavior are you trying to get back? The "wave to wake" functionality is gone, but other behaviors should still be present.
Just did the update - now my email (yahoo) isn't working - message "Email isn't responding. Do you want to close it? wait OK"
Any suggestions on what to try?
Clear the app cache for the email app. Also find the procedure for wiping the partition cache (I saw it in another thread on this forum). That seems to clear up a lot of issues.
I've downloaded the update a bunch of times, but it always fails during the update animation. A couple minutes after my phone resets, I get a message that "there was a problem updating your Moto X". Any ideas of how to solve?
I've tried to update my Moto X a few times, and every time I get an error during the update animation. After my phone resets, I get an error message saying "there was a problem updating your Moto X". Any ideas?
njira
