Looking for a case for extended battery
dad2noah
365
5
So I have this 4500mAh battery for the Sammy3. It adds alot of bulk, so I'm having trouble finding a case for it.
Not sure I could afford to bulk it up any more, but I would at least like an option.
Anyone know where us big battery people can turn?
There you go sir!
Basic case
TPU Protective Case for Samsung Galaxy S3 Extended Battery
Seidio Active Extended Case (Best protection for extended batteries you will need the Seidio battery cover)
SEIDIO | ACTIVE Extended with Metal Kickstand Case for Samsung Galaxy S III
I got an extended TPU case for my Gnex when I ordered the Hyperion 3500 from Amazon. Couldn't post a link but here is a screenshot, just do a search on Amazon.
What?! ...I'm msndrstood.
via Gnex
There you go sir!
Basic case
Thanks! The first link is the one from Gorilla Gadgets, which is where I got my battery from, so I know it will fit.
The 2nd link, was a very cool case, but it says it will fit a 3500mAh battery. I have the 4200mAh, wondering it if will fit? I'd snag that up in a second it if did.
I also found this on ebay, and am waiting a reply as to whether or not it will fit the 4200mAh battery.
I really do like that Seidio case.
Black Honeycomb TPU Gel Extended Battery Cover Case for Samsung Galaxy s III s 3 | eBay
Black Honeycomb TPU Gel Extended Battery Cover Case for Samsung Galaxy S3 s 3 | eBay
Ya. The Seidio site is confusing. They say that OEM batteries will fit, but give no actually mm size on the battery itself to know.
Then on that ACTIVE case. You can get the Active case and holster combo, and then they have a link right from the Active case and holster combo to their over priced battery saying this is a great match. Then you go to the battery and it says the holster is not compatible???
I can vouch for that tpu case, I have it on my s3 and it made it like a tank.
Sent from my SPH-L710 using Tapatalk 2
nemismom
