- Aug 25, 2017
- 3
- 0
- 0
Hi, I have a couple questions.
1. I (sadly) tried iroot to root my Huawei Y300-0151 and while I did a little googling on it I definitely didn't do enough. I've since uninstalled or disabled everything I can but I need to know what folders, files, etc it installed so I know what I need to delete manually. I currently have my phone rooted with Kingroot and plan to migrate it over to SuperSU once I have all of iroot removed.
2. I'm looking for the official Huawei Y300-0151V100R001C557B184 Firmware for Bell/Virgin Mobile Canada.
Anyone know where I could find this?
Thanks!
Edit: OK I found a firmware version on Huawei's website that has a different code but since it said it was for Bell Canada I downloaded it for further inspection. It came zipped with a doc file that says it is compatible with B184, it is just a more up to date version of the firmware. I'm leaving this question with this answer up in case anyone in the future ends up in the same place I was.
The firmware can be found at,
http://download-c1.huawei.com/download/downloadCenter?downloadId=31306&siteCode=ca
There were 2 other firmwares there for other Canadian phone companies but when I tried to link to them the link came up with a page not found, so just go to the download centre for the site linked above and do a search for Y300-0151 and you should get the page that has the other 2 firmwares.
Edit 2: Found a link that works. All you have to do is type Y300-0151 in the search box at,
https://consumer.huawei.com/ca/
and the first 3 will be for 3 different telecom's in Canada.
Thanks!
