loose volume rocker?
lucidlyseen
213
14
18
ok, so I might be picky at this point, but my volume rocker slides a bit up and down the phone length, to the point where if the phone is put down or moved a bit you can hear the rattle (looseness) of the rocker.
Is yours similar? Just afraid at 3 days old it will only get worse, but not sure if this is "normal" or not?
Mine slides but I have to move it back and forth for it. When I put my phone down, I don't hear any kind of rattle though.
Same here. I'm not going to throw a fit about it. I can't hear it making any noise at all.
lumaplay
