Losing battery while plugged on and turned off
Cinnamoo
So I'm running out of ideas here and I'm going to assume it's a bad battery, but before I order a replacement, I just wnat to double check to see if there's something else that could possible be wrong with my Nexus 7.
I have it completely off, tried it with various chargers that it used to work with (the original charger no longer works) but it just loses power even when it's supposed to be charging. Using the battery monitor widget, it'll say Status: Discharging USB Plugged (or AC Plugged). I've tried turning it completely off, wiping cache partition, doing a factory reset but nothing seems to work.
bantuanfintech
