Lost my note 5 N920C s pen!!! Need to order a replacement! Which pen can I order?
Anisha Pai
4
As the title says, I lost my s pen, stupid I know but I have been trying to order a replacement for a while.
Does anyone know if the note 4 s pen will fit into the note 5 and work just as well?
If not, does the model number matter when it comes to Note 5 S pens? for example, can I buy a Note 5 N920T s pen for my N920C Note 5?
I am so confused by s pen specs.
THANK YOU SO MUCH!
Anisha
Click here, and you should be able to purchase an original Note 5 S Pen.
I am only going off of the ad, please do your own research, but from the ad, it looks like it's an original S Pen for the Note 5.
Good luck! (oh, and turn on the warning, which let's you know if you walk away from your S Pen. Your Note 5 will beep, and bring up a message warning you that you've left your stylus behind if you move a certain distance away from it!)
I broke the click/click off mine and got a replacement at Amazon. It was for an ATT model but works perfectly on my T-Mobile. Sad that Samsung won't have any for a month. The store I got my phone at, also didn't have any.
heritagevine05
