Low initial volume when powering up Bluetooth
Amphicar
5
When I powerup my bluetooth or if it's lost connection (Jawbone Prime) the initial volume is set almost as low as it gets (not a Bluetooth problem, this only happens w my Droid) I have to turn it up on to full everytime. Is these a default setting for this that I can change?
I just got the prime a couple of weeks ago, and it started acting weird after I loaded the different voices. Try unpairing it and then repairing it, that worked for me.
That hasn't worked, there must be some setting I'm not finding. It always defaults to the lowest setting.
I use a jawbone and never had that problem. The volume is always were I left it.
I believe it is tied to your media volume. Look under menu, settings, sound and display then media volume. If this is turned down, this may be the problem.
I'm having the same issue. I thought it was my Motorola S9-HD headsets because I don't have an issue when I pair to either of my cars.
If anyone knows how to fix this please let us know.
Only when the BT is 1st connected and the volume key is depressed a window with "in call bluetooth volume" setting appears to set BT volume. I can not find this setting any other way.
tuovst
