I noticed this on my Pixel 3XL as soon as I updated, but I think the new design for how signal strength is displayed is just throwing me off. Before, the signal strength was represented by white with the remainder of the "signal area" greyed out, so it was less noticable. Now the signal strength is white but with a stark outline around the whole icon, so it makes the signal strength look lower IMO. I haven't noticed any performance issues.
The dBm signal strength is exactly the same on my Pixel XL at work and home as it was before.
The only true comparison method.
Unfortunately the PERFORMANCE tells a different story. My texts are failing, and I am barely able to stream now because of this issue.
Yup I got to agree. I wasn't in the beta's but My WIFI and LTE are worse than they use to be. Hope they fix it.
Believe that's mostly to do with RCS and some other carrier features. Most time the radios are updated in the system updates.My Carrier Services app from Google was updated last night from the Play Store. I'm wondering if this has anything to do with interface with towers and LTE signal? I restarted my Pixel 3 XL and now it seems my signal at home is more stable again and not jumping from 1 bar to 4 than back down to even zero bars at times. This could have just been temporary, so not declaring anything fixed until I try it when I get home tonight. Can't really tell at work because there is a Verizon transmitter on a street light pole only about a hundred feet away from my office window, so always 5 bars and a dBm level in the -60s here all the time.
