Low sound :( NEeed help
nimdass
13
Hi guys,
I racently bought a Bose SoundTrue Headphones for my galaxy s4 I9500. But the volume is low even at the highest settings. Tried some mods for that but nothing worked they just boosted the speakers. Any advice??
Thx.
There are some apps that promise to increase volume. Whether they'd damage your phone in any way I've no idea but you could look into them at least.
Hi guys,
Thx.
Hello.
Check your settings to see if you have some sort of "safe volume" option on. That's to prevent you from turning the volume up too much and damage your ears. That lowers the volume output and may be the culprit.
Sent from my HTC One XL using AC Forums mobile app
What are you using as a media player?
If you are willing to switch to PowerAmp you can use its Replay Gain function to significantly boost output volume.
Thanks for reply guys
Im using PowerAmp for player and I listen uncompressed flacs, replygain didnt work for me .s
Im considering fiio e6 for an amp but will it damage my phones as belodion said?
And safe listening is off .
Thx
[UPDATE]
Switched to Perseus Kernel. Sound is great now.
kimlien
