- May 3, 2015
- 1,418
- 0
- 0
I got a Fi Sim and popped it in. Works great. I turned off Bluetooth and it starts connected. Awesome. Unfortunately it burned 10% in a matter of minutes! Whoa! Emergency use only I guess!
it shouldn't be that bad unless you are in a bad signal area. I have Verizon connected to mine, and when in a full signal area, I lose 5-6% an hour(just the radio being on with no active use)
If you stream music over LTE, then yes you will lose about 10% in 10min as I did on my test.
