m9 battery drain..
delta7
826
6
18
I have a sprint m9 and the battery is just bad, literally it's draining not being used.
I use a application called greenery to hibernate applications that use battery like ad guard, Messenger and Facebook but the drain is still going in. I'm wondering if this is a sprint issue or just a m9 issue.
I just got an m9 a few days ago on Verizon and so far the battery is horrible. I know it takes a good week to normalize but today I was at 39% by noon. Hopefully it will get better.
I have the Sprint M9 and recently, I've noticed battery drain. Not sure why, not using it any differently than usual.
Hope Marshmallow helps.
I have sprint m9 battery drain the lte icon keep spinning and get overheat when it in my pocket.
poor signal so the phone works harder to search for one. found this a while back.
my phone sometimes just loses data all together and the phone gets quite warm. having a couple reset issues as well.
