Maintenance Update - 11/16/10
**PLEASE HELP**
I made the mistake of un-rooting and installing the new update for my Dinc. I no longer have S-Off and am unable to boot into Clockworkmod Recovery. I have tried to re-root using Unrevoked3 without any success. I've also tried flashing recovery without any success. Anytime I go to do something in recovery, I now get this error: " E:Can't open /cache/recovery/command". I then hold the vol-up and power and try to load the recovery file and get an error saying: "Install from sdcard. Finding update package, opening update package. E:failed to verify whole-file signature, E: signature verification failed, Installation aborted."
I have tried to go back to stock 2.2 so that I can hopefully root again. I put the update.zip file on the root of my SD card and go to recovery on my phone, getting the same error above, so I vol-up and power, then select the "install sd card update file" but get an error saying something like," ro.build.fingerprint=verizon_wwe/inc/inc/inc:2.2/FRF91/231334:user/release-keys invalid. Installation aborted."
Is there a way of downgrading the update? Can I re-root, or do I have to wait and hope the Unrevoked updates to be compatible with the Dinc update?
Thanks for any help.
You should try downgrading your phone using the RUU. Go the the shipped roms website and download the 2.2 RUU. This will wipe your phone and put it back to factory spec when 2.2 was originally released.
is there a way i can go back to stock without the stock apks? i have to return my phone on monday but i deleted all the stock apps.
RockoAndroid3689
