Marshmallow Update- Screen Mirroring Won't Work?
  • Start date Start date
@ShakerNL - you said @DonPistolon 's advice worked for your Note 4? I was previously under the impression the Note 4 was a locked bootloader and could not be rooted, but it appears that has changed in recent time.
1) Did you purchase an unlocked Note 4 somewhere, and if so, where would you recommend?
2) Or, if you found out how to root it, would you be willing to share your root method for the Note 4?
Ok. I have rooted my s5 sport and installed Root Explorer. I went into it as super user and found the file. System/build.prop . This is a huge file. Do i add wlan.wfd.hdcp=disable at the very end of the file or somewhere in it?
EDIT: ok, I found the information and placed the line of code at the very end. Sadly this did not work.
Has anyone found a solution?
OK pay attention I've got the answer to your problem the J7 lollipop had screen mirroring but android Samsung and T-Mobile conspired together to delete functionality screen mirroring android change the operating system Samsung change the firmware and T-Mobile profited by selling new phones ..1st of all android deleted. functionality so that you would be forced to purchasing their chromecast dongle, $50 and then Samsung help delete functionality of your phone in order to sell the J7 prime and T-Mobile just sells phones and makes money.. I'm in a lawsuit at this time against Samsung and android I'm positive I will be successful contact T-Mobile's Chief Executive officers office do not do executive response team they are stupid tell them they did this and get your new phone if your phone was a J7 lollipop in the beginning that is what you purchased and when they updated the phone they deleted your functionality we they stole it from you and you are entitled when these 3 entities conspired together for money this is called racketeering it is a crime Good luck
rosemar3
