Max MicroSD card capacity 32GB?
Batt4Christ
12
Has anyone tried a larger MicroSD card in their MeMO Pad HD 7? The specs say 32GB max size, but I know this isn't always hard-and-fast, unless it is an intentional roadblock, or a limitation in the firmware.
Just curious.
Just curious.
It may be a limitation of the ROM. Mainly the licensing behind the higher format.
Just curious.
I have read that a 64GB will work, but only if it's formatted FAT32. I haven't tested it, so I cannot attest to the reliability of this information.
I have a 64GB Class 10 in my Memo Pad HD 7. The tablet formats it exFAT but you can do it in another operating system before hand if you want.
sikkman859
