MC3 (AKA Premium Suite) [Flashable Zip]
Re: MC3 (AKA Premium Suite) Coming VERY SOON!!!
You chose to attack me personally, not my post. That is against forum policy. I do concede after reading through the XDA forums that there most likely will be an update coming some time this month, not "VERY SOON!!!!" I'm not going to respond publicly on this any further, but you friend, were in the wrong.
Joe, will this be an OTA update?
Re: MC3 (AKA Premium Suite) [Odin][TAR]
70% of leaks are never released. This just means it is being looked into. Will MC3 be it or will it be MD4? We'll know when it comes out.
As far as I know, you're the only one to speculate that sextape works for Samsung or Sprint. He does a great job of finding and posting links and mods and is indeed very respected. However, all of the leaks he has posted, does not become official updates.
But it is encouraging that progress is being made and there is an official update coming. This I know. This could be it.
But I will not be posting a update thread for it..
It is not a he/she... it is a group of people. And they don't give out their sources or how the get leaks, it's just all speculation lol.
Looks like the link is up
Is there a flashable zip file so we dont need to use odin?
Does anyone know how long the odin execution should take? Mine has been working for over an hour and still not done.
What are you trying to flash with odin? nothing you do in odin should take that long unless your computer is VERY old and slow.
I wouldn't flash this, it doesn't look official, but it is good to see. By May I would guess the final build will be out. Check out my earlier post and read about the leak before flashing. This is what it is, a leak, the first leak that drops from sextape is never an official update, as far as I remember. I remember on the S2 there were multiple leaks a week for ics.
Sent from my SPH-L710 using Tapatalk 2
I was trying to flash the MC3 one click.
I've disconnected the phone and now I get a screen that says"Firmware upgrade encountered an issue. Please select recovery mode in Kies and try again"
The phone is rooted and it will not start in recovery mode. It keeps coming back to the above message and Kies will not connect since it is rooted.
Probably going to an issue of which link you used to install this leak. Where it was one to freeza's thread or the one to sextapes. One is a tar that needs to be flashed in Odin the other a zip you can flash from recovery. If you made a backup I would try to restore that for now.
It was the one from sextape.
The phone will not do anything other than give me that same message anytime I try to boot into recovery mode/downloade mode or just try to power up
You can still get into both download and recovery mode though correct? Also is it a custom recovery or stock recovery?
davidlmcshane
