memory problem
Weng Omaps
15
hi can i ask how can i put back of my tablet internal istorage becuase before o have a lot of memory and now it became 00.0mb i already reboot wipe all data but not once or twice now i cannot download any apps yes im success with but the problem is i lost all of internal memory can anyone help me about my problem
So you wiped the storage, but it still says that there's no room left?
can u give me info? first its rooted and i unroot and i restart then the out come is factory defult then the internal memory is gone
tnx and here some the total is 00.0mb but at the lower it has a apps about 43mb
Could you clarify more on what you need more info on? You just install the file explorer, start the app, and then view any folders to see if they have any content in them.
You say you're rooted. Do you have a custom recovery as well?
Sent from my Galaxy S4 running SlimKat 4.4.2
no i dont have i was to download it but i think i have to unroot first i used z4 root
can i bring it back? i cant download anything its say's error downloadinh no more internal storage space
sir i cant download it say's always error downloading no more internal storage space
You can install a custom recovery with root. With that you can wipe the internal storage
how? i try to insall a small size but it still not work always error i reboot again and still 00.0 mb
even root checker i cannot download from play store because of 00.0 mb of internal storage
Try connecting to your PC and see what you can delete. Then download ES file explorer once you have enough space and use that to delete any app data that you don't need
Also to add to UJ95x's suggestion about connecting it to a PC, if there is nothing there, it might be a software bug...
Sent from my AT&T One X running CodefireX ROM Android Version 4.4.
I would suggest deleting some apps, text messages, pics, to generate more room, to allow some of the downloads
From a Sprint Moto X using AC Forums app
i'll try to see whats wrong maybe its a bug thays make my internalstorage 00.0 mb
KidColoringPage
