message settings help
Craig Mason
3
whenever i try to send a sms it gets automaticly converted into a mms how can i stop it converting into a mms as i don't want to send mms how do i change it back to sms by default?
Are you using the stock Messaging app?
If so, are you adding a 'Subject' to your messages? That will cause them to be converted from SMS to MMS.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
lumaplay
