messed up need help
Adamsmtch
10
i accedently deleted com.htc on my evo 4g and it started force closing so i turned it off then on and its stuck on boot. how can i fix this?
XD How do you "accidentally" do it? Were you rooted and thought that if you deleted "com.HTC" you would get rid of Sense?
Sent from my HTC Vivid WCX using Android Central Forums
Just dirty flash your rom..meaning reflash the rom without wiping and you should be fine
i bought the phone rooted and was trying to see what all i could do.so i had to do a lot more than that and i think i almost got it
this is what it show:
zip queue cleand
-- wiping cache partition...
formating /cache...
-- cache partition wipe complete!
-- wipeing delvik cache directories...
cleaned: /data/dalvik-cache...
cleaned: /cache/dalvik-cache...
cleaned: /cache/dc
-- dalvik cache directories wipe complete!
added /sdcard/jmzstock_vm_shooter_odex.zip
-- verify md5 for /sdcard/jmzstock_vm_shooter_odex.zip
-- no md5 file found. ignoring
-- install /sdcard/jmzstock_vm_shooter_odex.zip...
Sounds like your on your way...Good luck, let us know how it turns out
Well it looks to me that your trying to flash a rom for the 3d on Virgin Mobile
By the name of the rom.. vm_shooter .. i would assume the vm is for virgin mobile and the shooter is the 3d. If your on a 4G evo thats a supersonic
really everything but the one thing i do need is the ram cuz i hate slow phones and better internet connection. i just want one that gives me 100% control or close to it.
A AOSP rom will give you the most ram but might have issues with 4G and camera you just need to search through them and find one you like
well i use the 4g when i can it is just spotty depending on the area im downloading now and i let you no how it turns out
RichardDixon
