Military / Firearms wall papers?
Has anyone made any Rating Insignia wallpapers? I was a Navy Photographers Mate (PH now is MCS) and would like to find a wallpaper.
Not an easy process, but here you go... hope you like it... wasn't sure what kind of background I'd put on it, so I went with a fairly simple background. I worked with some very good PH's on the USS Carl Vinson up in OZ Division a long time ago... good group of people!!!
Reactions: Byzandroid
Thanks Very Much!!!!!!!!!!!!!!!!!!!!!!!!!!! Just what I was looking for. Even the background just right.
Charlie
Im new to all this smart phone stuff, can I pull the marine off here and put it on my phone as wallpaper, if so, how?
Simplest way, connect your device to your PC with a USB cable, enable your phone as a Disk Drive, surf the image you want, right click the image, select "Save Image as...", navigate to your device's SD card (example, it might be D: or E: drive), I created a Wallpaper folder on my SD card and save all my wallpapers under that folder... then click the Save button.
Disconnect your device from your PC... push and hold you finger on your screen for a second or two, select Wallpaper, you might have Home and Lock screen as separate selections if you do then select Home, the Gallery... this will search your entire gallery, find the image and select it... done.
Anyone mind hooking up a USN SWCC by resizing these for my OG Droid?:cool:
I just found a these in a much larger format... if I worked with your original images the wallpaper would be very, very grainy. I'll try to post these new wallpapers a little later today, or tonight.... please check back.
Reactions: cmorty72#AC
This is the nice collection and nice wallpaper i ever seen,Really all wall paper are very creative and beautiful,hope you post more wallpaper in future.
amateur_user
