Mini HDMI or Micro HDMI?
Thanks for the heads up on the cable difference. I almost ordered me a couple of them. I will look the the MICRO HTMI TYPE D in the future.
Looks good to me and it says in stock so i would jump on it!
I was looking at this cable. Anyone familiar with this one or this site?
HDMI Cable
Maybe want something longer though.
If you click on the questins tab on the product page, someone specifically asks if this cable works for the Evo 4g and they are told that it isn't the micro size that the Evo requires. I'll keep looking too fellas.
I just bought mine from Arrow today for $18 including shipping. It's a little more than DealExtreme but it's also twice as long. I didn't think 1M was going to be long enough for me. Hers is the link again to the Molex HDMI A-to-D 2M cable.
http://app.arrownac.com/aws/pg_webc/0,1086,,00.html?application=SEARCH&event=1009&search_token=687860003&search_criteria=match_begins_with&match_in_stock_only=NO&=&rows_to_display=10&limit=10&full_domain_name=app.arrownac.com&super_neda=&start_index=0&search_type=click_through
Folks, I just got my HDMI cable from Arrow (from the link above) and I can verify that it does indeed fit the Evo! When I get home I can test it on my TV and report back on the results.
I would appreciate the report, including from the EVO side (i.e. what you can do, if anything, on the EVO screen when you're plugged into your TV with HDMI). Please try it with different applications beside video. Thanks in advance for any info!
That one would work but it's only 1m long. The one from Arrow is 2m. May not matter to most, but just pointing out the differences :-)
How about this one: Micro HDMI to HDMI Cable,HTC EVO,XT800,F85EXR,SH-07B - eBay (item 120578122978 end time Jul-02-10 03:14:03 PDT)
eBayISAPI.dll
I posted about what I found works and doesn't work in a previous thread:
Works OK for me but it's a bit picky. I'm finding that per the instructions I do need to first power off the monitor before connecting the EVO. Still images only work in slideshow mode but the slideshow controls are visible on the EVO while the slideshow is running on the monitor. So you can pause, go forward and go back. Videos work fine from the gallery app, YouTube app, and TV.com app. SprintTV did not work though (not a fan of that app anyway).
Thanks for the heads up on the cable difference. I almost ordered me a couple of them. I will look the the MICRO Mini HDMI TYPE D in the future.
elowen89
