MIPErrorActivity Galaxy s4 problem
Odd Future
Active member
May 27, 2013
36
Every time I restart my s4 and open my task manager it says MIPErrorActivity. Does anyone know what this is?
Pretty sure this is just a bug with the mf9 update.
Some think it had to do with wifi, though I would get it with wifi turned off.
I think the general concensus is nobody knows what's causing it exactly, from what I could find.
If you're rooted you can freeze the notifier app. I haven't noticed any effects from freezing or leaving it running.
I'm on Sprint, not sure if everyone has the bug but it does appear Sprint users with the Mf9 update do.
I'm also on sprint and I did notice that it showed up when my wifi turned on too
Sent from my SPH-L720 using Tapatalk 4
vickyy
