Missing pictures from SD card & deleted apps? SD card problems
Alright, so it looks like there is no corruption.
You can also format in the command window. Type "Format f:\\" without the quotes and hit enter.
what's the part about "windows unable to mark the volume as clean"?
Not too familiar with the command window errors.
Did you try viewing the files in your phone with a file manager?
Sent from my Galaxy S4 running SlimKat 4.4.2
I can view the files normally in my phone so I really have no clue whats the problem.
Use a file explorer to delete them. You should be able to do it as a folder, so you don't have to do everything one by one.
Deleted everything except ".android_secure" (couldn't delete)
Went on "Storage", told me that I have 59.something space available now
Formatted right there on the phone
It mounted back unto my phone with all my files right back there
Wow...
If none of that worked, I think the only thing left to do is to get a new card :(
Sorry we couldn't get it fixed.
Re: Missing pictures from SD card & deleted apps? SD card problems
Wow...
It's okay. I believe I've tried everything, even a normal Windows format but it hasn't worked.
I'm just not sure if I should get another card because I've read this post: Galaxy S3 - the sd card destroyer - xda-developers
- - - Updated - - -
Wow...
Thank you for all your help by the way :)
- - - Updated - - -
Well you could try out a smaller capacity card and see if it happens again. That way you don't flush $50 down the drain if it fails.
No problem :)
See you around the forums
No problem :)
I'm having same problem with my Note 4. Started out using 64 gb card from my Galaxy S5. Kept getting message that my card was corrupt, deleting apps and pictures. Luckily, I have my pictures automatically sync to Facebook so I didn't lose those.
I replaced sd card and am still having problems.
OK here is the thing i am having the same problem with my sdcard are phones wont work with some memory cards here is a list of ones that work for me and ones that don't
work:
1. samsung evo
2. sandisk
3. sandisk extream
4. samsung pro
5. sandisk ultra
dont work:
1. micro sdcards works but erase apps/photos/roms etc
2: micro xc Patriot
3. lexor 300x
so the ones dont work has issus hope this helps you.
pmm09
