mobile network using power when turned off
Pizzabager
Active member
Jan 14, 2019
26
the batteri on my watch 4 lte is getting less the 30 hours and im really only using the clock. i turned the mobile network on the watch off, cuz i could see it watch using alot off battery, but the batteri use is the same. mobile network batteri use is at 46% Even when it is turned off.
i Was writing with someone Who also has a watch 4 with lte on, and usage off batteri on mobile network was 0,1% when mine was at 46%. anyone Who has the same problem or know Any solution?
I'm not convinced the battery usage reports for the watch is 100% correct. I see usage for stuff I don't use also.
But its the same every day, mobile network is the largest consumer of battery, and much bigger then the others.. today its at 12% and battery is at 43%
BennyHuyghe
