[MOD] - CRT Power Down Animation - gROM / Opti-ROM
No I'm using gROM 2.1. No custom theme at all, in fact, I just tried to install the mod and it did nothing to the phone.
emo I'm going to ask a question, please don't take offense to it I am asking just to clarify: Do you know what exactly it is that this mod does?
Yes, i do, it changes the screen power down animation.
And to just let you know, this is the same animation that is available in the CM7.
I'm using 2.1 and I'm pretty sure it was on by default, I'm also using a custom theme and it still works. I don't remember enabling it anywhere. At first I thought it was a glitch of some sort lol but I like it.
What theme are you using?
Its enabled by default on 2.1. You should not flash these zips if you are on 2.1. They will mess you up.
Got it fixed! I had to do a wipe and re-install. I'm not sure why, but it worked now. Not only that, but gmail is now working like it should. LOL
It may, I have not tested it. You would most definitively loose that pretty dark theme they made though! This will revert you to an almost stock theme.
interesting thanks for the heads up. i've started to fancy their theme...
selenasw
