[MOD] Harmonious Bumblebee 2.2
Is anyone having trouble with Lockups? I.E. having to pull the battery. I just flashed this ROM yesterday morning and have had to pull the battery at least 5 times. Also, my Yahoo and Facebook accounts keep disappearing on every reboot. the only one that stays is my gmail.
It's probably a bad flash, unless someone comes forward with the problem as well. I'm a bit busy today but when I was running HB 2.2 it ran fine, so maybe if I have some spare time I'll check just for the fun of it.
Thanks, I appreciate your time and response.
I cant get google maps ti update. So I uninstalled it and now it will not reinstall. I'm not sure if this has been covered in this forum.
I could not get google maps to update. I uninstalled it and now it will not re-install, downloads then reboots before install is complete. I don't know if this has been covered in this forum.
Hi, I was just wondering for some clarification, sorry if it's a stupid question... The "wifi hotspot built into menu systems" that you metioned refers to hotspotting for free correct? Or is this only if you pay for hotspotting in your plan? Thanks
ive downloaded update_bb_rom_2.4 zip ,what do i need to do next ive already flashed and did a nandroid back up ...do i just wipe dilvik and cache and install it or do i need to install a diffrent version of (BB) please send a link of bumblebee that i can use with the optimus v ...thank you
Are you trying to upgrade from Bumblebee or starting fresh with a new ROM? If you're trying to update from Bumblebee then I'd suggest wiping cache, system, and Dalvik. However I do not know how well that will work because I've never tested that...
If you're trying to install Harmonious Bumblebee then you don't need the bumblebee zip. You only need Harmonious Bumblebee 2.x if you have a newer OV, or any of the HB zips if you have an older OV.
EDIT:
Nvmd, I think I figured out how to flash this ROM correctly. It took a few tries but it seems to be working out great so far. Thank you!
Just one question; is there a way to turn on live wallpapers selection? I payed for one I really like and would like to use it.
What can be the problem with my stock Gallery crashing all the time?
yes its overclocked... with the default overclock (748/245/inter./deadline) Harmonious Bumblebee gives me: it crashes.
with recommended (729/480/onde./noop) Optimus V settings: it crashes
anyway to figure this out or fix?
It's either a bad flash or your overclock settings are too high. Sadly not all OVs were created equal in the overclocking aspect, some can get up to 806, some can only get 748. It's kinda ducky but oh well. As long as it gets up to at least 600 there's really nothing you can do about it...
Sent from my Transformer TF101 using Tapatalk
EDIT:
You would have to grab the LiveWallpapersPicker.API from another Froyo ROM to enable Live Wallpapers
Use Quickpic on the market. Best Gallery ever. :P
i've tried using 600/320 and it still crashes...
everything else works fine mind you, which is weird :eek:
this has been my third flash... first one would crash alot... second not so much... and now third is just crashing my gallery and sometimes the camera.
I have used recommended flash files for new 2.2.2 OV
HB 2.2 (HB-public22-2.zip)
Picastix for new screen problem 'flashed with signature off' (pica07remix.zip - 4shared.com - online file sharing and storage - download)
flash img (flash_image - 4shared.com - online file sharing and storage - download)
recovery (VM670NH_recovery.img - 4shared.com - online file sharing and storage - download)
any ideas or other file recommendations?
thanks for the reply
Gallery is fickle, it can crash even on stable systems. Certain versions are known for being extremely crash prone.
It wouldn't surprise me if just accessing certain files will crash it. As mentioned, try Quickpic.
mostafamu
