[MOD] Switch Internal for External Storage
can you solve this ...?
i have problem with my internal storage " USB Storage is Damaged.Try Reformatting it"..so ican't use my camera and cannot open my gallery.
it's begun when i try to move some files from my pc to my laptop, i using my internal storage like a flash disk. but it's not working ,,so i unplug the cable from my pc. and after that all.. my internal storage is damaged.
i've tried to format everything and i've tried to change my rooms but still doesn't work
can you tell me what should i suppose to do ?:'(
Are you talking about the internal storage in your phone? Or are you talking about an External SD Card?
If you're referring to an External SD Card, I would turn your phone off, remove the card, using a card reader, take any files you need off of it (and put them on your computer for the time being). Then, take the card, put it back into your phone, and power it up. Then under Settings>Storage, there is an option all the way at the bottom to format the SD Card. When this is complete, power off your phone again, place the SD card back into your computer, transfer the files back onto it, place the card back into your phone and power it back up.
Now, if it's internal, this may be a whole other issue. However, this MAY fix it (assuming there's nothing wrong with the OS files)... Using Clockwork mod (or another backup program, assuming you're unlocked?), make a nandroid backup, and save it to the EXTERNAL SD card. (Because you DON'T want to lose your current ROM and all your information.) Then, power off your phone by doing a battery pull, take out the SD card, then boot into recovery by holding the Volume Down and Power buttons at the same time. If you're using Clockwork Mod, you can go under Advanced (I believe), and format anything that has an option to format. After that is done, do a battery pull, place your SD card back in the phone, boot into recovery and restore the backup you just made.
A few things to note though, if you still have the same issue, you may want to try and install a new ROM. Use software such as Titanium backup to make a backup of all your apps and information first though, being sure to save everything to the External SD Card. (There is an option under settings to change the path to which the backups are made). If you still have issues after that, there is a possibility that the actual phone memory may be damaged. With that being said, you would have to undo your root, and take it into a VZW store to have them replace it.
DonJrPlayz1234
