Modem clarifications please
So what are you missing? Wifi speeds still? The fi03 leak has really decent wifi speeds. On cm9 I tap out my router. Also on distance it picks up the signal still about 75feet away. Have you tried restarting your router?
sent from my BAD A$$ Epic touch
Usually it would be wifi.. Going from GB TO ICS. I also lose ability to be hotspot at times.
When we flash the rooted otas el29 : ff18 : fh13. Do we do wipes or flash over them
My end game is cyanogen 9 or 10 with my services. So far I sm usually missing wifi then data. I have done it with and without. No wipe appears to work best. Also I have made sure not to flash individual parts as of yet a modem. Etc. I would like to have all working if possible. Wifi will connect after GB . However usually it will not see networks until it is on top of the router. . . Literally.
Ok I know you can use mobile home don't however it does not do well with the modem can use it for the kernel.
also when your flashing is the equipment you're using have to have internet connection.
let's make sure I got this right the kernel goes in PDA. Modem goes in phone slot?
Sent from my SPH-D710 using Android Central Forums
Not sure what that first sentence even was. But #2 no you do not. #3 yes that is correct.
My spologies as i was in Hurry and didn't catch the mistakes from using voice to text key board. Was saying was reading mobile odin could be used for all but the modem.
That confuses me i would figure the kernel would error as well not sure why, i am new and still learning.
It kernal failed however on install pc to phone. How long is the kernel and modem flashes? Not sure why it failed yet. Will look when have more time. Had to go to work.
Kernel is the fastest. Maybe a minute or two. Modems come in just behind that. I believe 3-5 depending on which version. Mobile odin is for everything except modems. Make sure to only have reboot checked in odin. Also if it failed try a different usb cord. Maybe yours is faulty and loose.
Thank you for your patience and not supporting to me like i have same personal knowledge base as yourself. I am in IT and find most do just that. Sometimes the most trivial of things to the experts are most important to us newbies and makes a difference between having the information and understanding it.
thank you for your assistance. Unfortunately I wasn't able to complete everything and report that you got me through this as my Galaxy S2 was Stolen. I appreciate your time and patience and hope I find that in future postings. currently have LG Motion and am going to search for a ROM if one is available and hopefully find one where any and all references to metro pcs are gone. :)
once again. thank you
thomas
visionarysearchist
