Most stable ROM for Fascinate
I have a fascinate I had asked my stepson to root my phone scince he had managed to root his driodx without any problems but he semi bricked it... I had managed to get a stock install back into the phone and get it working... and feel that if I could do that, I should be able to root it :)
This is what I have
Firmware
2.1-update1
baseband
S:i500.04 V.DJ05
Kernal
2.6.29
build
Sch-I500.DJ05
Ok, I would just like to root and put in a stable rom .... I would like to underclock or just get something without all the bloat... I was thinking the lastest superclean. I would pretty much like a step by step walk through from someone with time on their hands... :)
I already have Odin setup on my pc...
This is what I have
Firmware
2.1-update1
baseband
S:i500.04 V.DJ05
Kernal
2.6.29
build
Sch-I500.DJ05
Read the stickies... all the step-by-step walk throughs you could ever want are there
This is what I have
Firmware
2.1-update1
baseband
S:i500.04 V.DJ05
Kernal
2.6.29
build
Sch-I500.DJ05
Go here---> http://forum.androidcentral.com/ver...ed-custom-roms-w-root-updated-06-12-11-a.html
The all in one ODIN package links and walkthroughs are there and I would take a look at the two that are there under "CR 2.0"...
You have an option of using either but one does not have the Modem file and you are left with the one you have on your phone now...
HOWEVER you are currently using DJ05 and I might look into letting the phone OTA update to the newest version. (ED04 Baseband). Then ODIN the package without the Modem and you have the newest baseband plus a very nice ROM with an undervolted kernel :-)
Or you could use the other link that has everything you need including a fairly new modem which some will argue works just as well.
superclean needed
Superclean 2.9.2. If you are proficient at rooting and flashing, you can load the EB01 modem in ODIN and the Superclean ROM in clockworkmod recovery. Or if you are not proficient, you can use DroidXcon's all-in-one ODIN packages. Just let me know which you want to use and I can direct you.
hey there landshark how can I go about obtaining this ROM?
Loaded CommRom with 2.1 patch on my GFs phone as suggested by my bro droidxcon, and she couldn't be happier. Thanks DXC.
Which one are you referring to? Here's everything you will need for either way:
EB01 Modem => eb01modem.tar
SC 2.9.2 nonvoodoo => super_frankenclean_2_9_2nv_CWMFIX.zip
SC 2.9.2 ODIN file => MEGAUPLOAD - The leading online storage and file delivery service
For the ODIN file follow the directions in this thread:
http://forum.androidcentral.com/ver...tom-roms-w-root-clockwork-updated-3-25-a.html
SuperClean has been replaced by Community ROM, so there is no more support for this ROM, FYI
sukarisw12
