Motion sensor and vibration not working
daronmal
8
My phone, within the past few days, has dumbed down or something, the motion sensor no longer works at all, and the vibration when I get a text or call doesn't work anymore either. Should I reset the phone? I really don't want to, but I will if I have to.
It's impossible to say for sure what's wrong with your phone. You should only go through a factory reset if you've tried absolutely everything else.
I will say that the vibration motor crapped out on my Turbo 2 when I owned it though. I had Verizon warranty replace it for me.
Bride96
