Moto Mod Battery 2200
Thanks for that graphic. I couldn't find Moto Mods on my phone so I went to Play Store and it showed I had on my phone but it was disabled. I enabled it and the battery shows up now. I'll charge for a little while and see if that solved the problem.
bill-e, seems you solved my problem. Battery is now charging. I'll have to return the replacement coming from Amazon.
The problem with the bumpers depends on which one you got. The "original" one had a larger tab on the back at the bottom that keeps some mods from seating properly, as well as a smaller opening for the charging port. They then released a revised model that addresses both issues and works fine with mods.
ameliadinkins
