you may have already installed it if you have automatic updates set.Where are y'all getting the update from? I don't see an update on the play store.
Seem to have solved this problem. After I disabled the Motorola Assist, it disappeared from my Apps page. I then noticed that the Battery Saver was not staying on. Not sure if this was happening before and was a part of the battery drain connected with Motorola Assist, or if the phone was now "misbehaving" as they had warned because I disabled a preinstalled app. But anyway, when I would turn on the Battery Saver it was turning right back off. So I reset the App settings to default and turned Motorola Assist back on with all the options. I then went into Google Play and adjusted settings to make sure apps do not update automatically - The Motorola Assist app had updated and I suspected that update was maybe causing the problem. So now I have not charged the phone at all since last evening, and it is still at over 80% battery left, even though Location is turned on and I am using a live wallpaper screensaver.
The problem was a New Year's Eve bug and it resolved itself today. However, the update they pushed is supposed to prevent it from happening again in the future.I suspected that update was maybe causing the problem. So now I have not charged the phone at all since last evening, and it is still at over 80% battery left, even though Location is turned on and I am using a live wallpaper screensaver.
This update a few people mention, is that the Dec 19th update or a newer one?
This thread should be closed. It was a New Years Eve thing and it's all good now
yes, that is what the motorola engineers said. They said everyone would be fine today and we are.I'm thinking this was a calendar day bug personally. I wouldn't be surprised if everyone who had problems doesn't see them tomorrow.
clear the cache, disable the app, reboot and then re-enable the app.All I know is that assist is still running funky for me... Ive been getting these battery drains from assist for the past week and a half.
