Motorola Droid Tips, Tricks, and Easter Eggs
Wish you had a launcher to your favorite website?
Save your website to Favorites, then open Favorites in your browser. Longpress on the website icon and select Add Shortcut to Homescreen.
another way to do this, is bookmark the page that you want to launch.then go to your desktop find an open space, press and hold that space and select shortcuts. if you use oem browser, select the red bookmark tab and select your launch bookmark.if you use dolphin, scroll down further until you see m. geek bookmark, select that and your launch bookmark...
Want speed dials?
Go to blank space on home screen / hold down / select shortcut / select direct dial / select contact
If you have a picture for the contact their smiling face is on your homescreen. Touch it and your dialing.
Note: also works for one-touch text messaging. Select direct message rather than direct dial. The icon will have a little phone picture in the corner for the dial shortcut and a little talk bubble for the message.
Another note: the icon will have a large letter in the corner to indicate which phone number you selected as the shortcut (M for mobile, H for home, etc.)
If you have a home replacement app like dxtop or pandahome, dedicate an entire screen for speed dials. With the picture and the name and the option for text message shortcuts its pretty sweet. Also, some homescreen replacements have "sidedocks" that slide out. They're pretty handy for having all of your phone speed dials on one side and all of your text message shortcuts on another sidedock.
Sorry if this was posted earlier. If you have an annoying contact that keeps calling you (like a bill collector), you can go into that contact, select menu, and then options (not edit contact). In this sub menu is an option called "Incoming calls", checking this box will send this call to voicemail everytime. The phone won't even ring.
Reactions: mnassour
Go to Google Maps and search for your house or a well known site; or simply press and hold somewhere on the map. A bubble will appear containing the text of what you searched for or the location you touched. Touch the bubble and you will get a menu. Scroll down to Street View and click that - it will show you a street-level image of that place that you can scroll around in - pretty cool, right? Now, this is where it gets really cool - touch the menu button and select compass mode - enjoy!!! :-)
If the image doesn't seem to follow your movement, wave the Droid around in a figure 8 which seems to recalibrate the compass.
This only works if the location you selected is on a street that has a yellow line overlay on the street. This indicates Google has taken the drive by photos of that street and has street view available. And unfortunately they havent taken photos of everything....yet.
Thanks for all of this, everyone! Just got my Droid recently (traded some poor sucker for an HTC Eris) and this has really helped!
It's been suggested to set-up the card with the following structure:
/Media
Alarms (Folder in Media)
Ringtones (Folder in Media)
Notifications (Folder in Media)
/Music
/Pictures
/Videos
Where the Ringtones and Notifications can have duplicate files if you want.
Ok Total newbie to my droid. Under my SD card, I have directories of:
\DCIM
.thumbnails
100andro
Camera
\google_maps_navigation
\LOST.DIR
Am I supposed to put the said structure under the DCIM folder or get rid of it and make the new folders?
Thanks for the help
\DCIM
.thumbnails
100andro
Camera
\LOST.DIR
Thanks for the help
Just ADD the folders to your root directory on the card. You don't delete the DCIM folder.
Great post. Just got my droid a few days ago, and these tips have helped me out big time!
dont know if someone mentioned it but for all those that gripe about no dedicated keys for number all you have to do is hit alt twice then the top row is numbers till you hit alt again
Maps app is great, but it's easy to make it even better...Open up Maps, then click on the menu button, then select "More". In the popup menu click on Labs to access a list of enhancements, where you can select any of several additional features for the maps app, like a distance scale bar on-screen. There's several other cool additions for enhancing Maps, so turn them on and off to find what you like.
Handcent-Am I the first??
Ok, there have been some posts about making specific ringtones for specific contacts for text messages. I did some searching and haven't found this posted so I'm hoping I actually came up with something that I could repay all the great advice everyone has given me. If you are using Handcent, you can assign specific ringtones for specific contacts. This is the only way I know to do this...
In Handcent, when you receive a text message there will be a little icon in the upper right hand corner of the screen with a silhouette and a gear. If you press that it will take you to a settings screen. I have played around with this and if you change any of the settings in this screen it is for that specific contact only. If this is already known, I apologize for the re-post and I will bow my head in shame and curl up in the fetal position.
General consensus is that you can't use the Droid hands-free. I just set mine up using the bluetooth handsfree built into my Nissan Frontier and it works perfectly. You do have to set up the phone book numbers in the vehicles system settings, but I can just push the button on steering wheel, say who to call, and my Droid places the call. My Motorola H500 earpiece works fine also. Don't buy all the 'expert' opinions you see on forums - just go ahead & try something before you blindly accept that it can't work. I tried it and it works beautifully both making & receiving calls.
*#*#4636#*#* brings up a series of menus that provide interesting details about your usage and the ability to modify how your phone uses the PRL. I don't recommend messing with it but it is interesting, nonetheless.
Where exactly do you type this? Same with the other ##Program one I can't figure out where to put it. The other post said in the call screen but it didn't work for me. Let me know thanks
You type it as if you were dialing it. As soon as you type the last digit a menu shows up.
ok the 4636 one works but what about the ##PROGRAM. Is it the same thing or something different because that is not happening.
nevermind when i tried this last time it didn't work. Works find now thanks.
y it is not working in mine
aktivasipinbnimobile
