Motorola Xoom Hints/Tricks/Tips/Information...
Where do I find how to clear the history and cache? I looked in settings and couldn't find it there.
Open the browser.
Open the menu (four hash marks in the upper left corner of the screen)
Open settings.
Open Privacy & security.
From here you can...
Clear cache
Clear history
Clear all cookie data
Clear form data
Clear passwords
How do you remove photos?
Use a file manager (Let's use "Open Manager for Tablets" as the example, because that's what I use.).
Open the file manager.
Navigate to the photo(s) you want deleted.
Long press on the photo you want gone. A menu opens at the top of the screen. You can get info, you can delete, rename, or copy.
Other file managers work similarly.
Hi everyone I am a new Xoom MZ601 owner and I seem to lost the compass. Can anyone tell me how to get it working again.
Thanks
so im curious if this ( Logitech - Keyboard Case for Samsung Galaxy 10.1 ) will work with the xoom. i looked at the specs and its the same as the galaxy, so it would be fair to say that it would work the same.
as for the bluetooth part, i know it will work, but im talkin more about using it as the face cover.
or is there one made specific for the xoom, but i been looking and havnt found one yet.
thanks
G
Thanks for the tips. Do you know if the Xoom has a ecompass as google star map does not work properly on mine.
I've noticed that since I upgraded to ICS when I turn on my xoom I have to choose open or camers. I can no longer touch outside the circle to open. Am I doing something wrong or is it set up this way.
You have to drag the circle to the lock to unlock or to camera if you want to use that. Nothing happens if you just touch outside the circle.
Hi sir I am just new in using android. I have my moto xoom wifi only and I would like to ask if there is already an application to activate the sd slot of my xoom honey com 3.0. Tend
What country are u in? The sd card is tricky on the xooms.
Open the browser, go to settings, privacy and security, then look for clear form data and clear passwords. You can also specify whether or not the info is saved.
I am not sure of the issue exactly, but it appears that my xoom does not have a 'dictionary,' as it were, installed internally.
That is, everytime I type an email, a note, or a word document every word is underlined in red as not being recognized as a word in the english language. The only way to remedy this issue I've found is to add every word to my personal dictionary.
It seems like there should be a way to update my xoom's internal dictionary w/o having to add every word in my personal vocabulary, so it knows I am spelling the words correctly.
Thank you in advance.
N r
redmercer
