Move video from internal storage to sd card
These screenshots are from the preinstalled file manager, not ES File Explorer, right?
Also, are you certain the phone is recognizing the SD card? If you go to Settings>Storage​, does the SD card show up there?
Thanks... But Yea... It's there.. And I'm using file manager that came with the phone not es manager..I have to admit I'm baffled...
I'm sad and glad to hear that I thought it was just missing something that was obvious to everyone else
What if you try a different 3rd party file manager, like Total Commander or Solid Explorer? I'm not a fan of ES File Explorer, ever since they started adding lots of useless (and suspicious) junk from DU.
Hey man... Thanks so much for taking the time and helping... But I went to settings and then storage.. I was able to move the video easily... After I moved the video I had to hit refresh on the sd-card for the video to work, but it did.. Thanks again for taking the time...I thought there had to be some simple way to do this, but I had no idea...
LOL, there you go! I find that preinstalled file manager apps tend to be clunky, which is why I like some of the 3rd party ones that were mentioned previously.
allenandrewfavia
