MST on Note 9?
In the 3 years that I've been using Samsung Pay I've tried it almost everywhere. The only place it doesn't seem to work is Lowes.
Apparently it works at Lowe's if you let the 15 second timer run out and try again, the 2nd attempt will work.
Just used Samsung Pay at Home Depot, Lowes and Chickfil-a. Only problem was the cashier at Home Depot swearing it would not work. When it did work, she was amazed.
MST is the best feature of Samsung Pay, without it I would no longer use SP.
I have used mine at Lowes, Home Depot, Wal mart, Sam's Club, Starbucks, Subway, CVS, Walgreens, JcPenneys, Kohls, AutoZone, PetsMart, McDonalds, vending machines with a card slide, inside at Sheetz, at BP, Country Fair, Pilot, Giant Eagle, Heinens, Staples,Applebees table readers and Applebees monitor side readers,Cracker Barrel, chipotle a few times.
I like it because I know it will work if I have access to the card reader, no matter whether it says android pay accepted or not.
Those of you with issues at Walmart a d Sam's Club: choose debit as a selection and enter the 4 digit pin for the card
I would also add that, at Walmart, even if it beeps an error keep it pressed to the card slot. It will take it. Might take a few seconds but it will go through. My experience.
Thank you, could never get it to work at Walmart before.
Just tried Samsung Pay for the first time on my Note9 and CVS and no go. Irritating. Maybe it wasn't fully setup. It looked like it was.
I ouldnt get it to got through at Lowes today. Last time I tried several times before it worked. This time there was s luck someone behind me so I did t waste much time.
gianfranco
