Multi View Update Screen Rotation Bug Confirmed.
I was just posting that for other people who have the issue - as to your advice thanks. I'm just thinking if i want that security update I have to do the other update and I would be in the same boat - and I wouldn't want to get a phone with other issues.
Oh ok.
No you wouldn't necessarily be on the same boat. I have all the updates and I'm not experiencing the issue, many aren't.
Sent from my AWESOME Note 2
Basically, if I had a problem before the 14 days, it would go back to the store, after that, I would probably send it to Samsung, even with AT&T willing to trade it out under warranty.
Just got off the phone with a really nice guy from AT&T named Craig - he researched the issue and found out about it on Android Central - he told me that returning the phone wouldn't resolve the problem because it's clearly software. He called Samsung for me - and they suggested that a fix was to do a factory reset and he told me that samsung is waiting on a fix for this problem.
But..everyone isn't having that issue. You might want to reflash your phone then..maybe something went wonky in the update. Is there an AT&T Device Center near you? If not, Samsung says you CA reflash yourself via Kies. I have NEVER done that, so I don't know anything about doing it. It might be straight forward once you connect to Kies though.
You can try the reset, give it a few days, you still have 9 days to take it back to the store.
Do you keep multi tab turned on? I don't and maybe that it the culprit.
Go to any app, hold back to show multi-window apps tab (you don't have to pull out the blue tab), now rotate phone. It works for me like a charm. You can hide the multi window tab if you want afterwards.
_____________________________________
Best Buy now offers permanent price match against all stores including Amazon and online stores :) - The Galaxy Note 2 is better than sex! - Tapatalk HD 2
I just did two things - in nova launcher - my screen rotation was set to default which says "normally" locked - I just switched that to auto rotate- I also just turned off multi view per your suggestion Kelly - I don't really see the need for that on my phone - I do use it on my Note 10.1 table though (I guess because the screen is bigger) I haven't had the problem all day - so I am hoping I won't have to deal with it again.
AT&T said it may be a 3rd party app thats interfering with he multi-view- but they said it has to be software.
I love this phone the only issue I had was this one and I'm not a fan of the shiny bezel (I can see this getting light scratch marks like my old iPod)
Yeah I saw you posted this - I was just trying to make sure it was a software problem and not a device issue
It could also be Nova causing it, even with the seeing change. The only launcher I have on my phone is Home 2 to make my Voice Search work like S-Voice. I don't use launchers either. I did for a while when I had my Captivate, but they always caused problems for me, no matter what launcher it was.
Just tried this it didn't work
HA HA HA when all else fails...which amounts to much of nothing, AT&T mutters those dirty words...." Factory Reset "
- - - Updated - - -
Pull your Battery...leave it out for a few minutes, put it back in. Reboot. Let us know how that works
cinemacritic
