- Jun 13, 2013
- 2
- 0
- 0
Do you know where I can get the file Flashbarservice.apk ? I ran an app called Multi window manager which basically adds whatever apps you like to the floating bar. It batched my Flashbarservice.apk.
Now I have a note 8 with note 2 floating bar @@, which is tiny and crashes everytime I use. The only solution I can think of is replacing the file. I restore the backup but the bar was not back to normal.
