Multiple edge panel tabs? Possible?
sjl81
4
Hi, just got my S7E and getting to know it. Just wondering, I've found how to move the edge panel tab up and down in position on the screen, but cant find how to add extra tabs, is this even possible?
No, there are pages in the Edge Panel that you flip through (you can also tap the dots to jump to a particular page, just like with the home screen dots). You set up which pages (panels) you want to use by tapping on the gear icon when the panel is open. Some panels came installed on your phone and then there are others you can get (some free, some you pay for) from the Galaxy Store - hit "Download" in the Edge Panel Settings to see those.
Not sure if there was an update but I just got a new S7 Edge and there IS an extra Edge tab. It's driving me crazy. It's linked to messaging (I think). I disabled the standard Samsung messaging app and use Chomp but the tab still pops up on occasion.
brucestark2741
