Music Player showing wrong cover art
thank you so much it worked and i use media monkey
Hello Everyone! :)
I have same problem, but I am already solved this. Just delete all files in directory /storage/sdcard0/Android/data/com.android.providers.media/albumthumbs/ and re-open your music app
Good Luck!
just wanted to let some know that i use Media Monkey on my phone and it searches automatically the album art for the songs and appends them to the file. I deleted the album art like you said and just let Media Monkey do its thing.
Thank you again for the fix, this was driving many of us made..
Hello Everyone! :)
Good Luck!
First of all, thank you so much for this solution.
Ok, so I have a Samsung phone (Note9) with Samsung Music. At first, this step didn't solve my issue. So I would like to share that for Samsung Music users there is an additional step, and that is that you need to first force close Samsung Music and clear it's data, and THEN you need to delete the things in the albumthumbs folder. After you did this, Samsung Music won't have permission to use storage, so go into Samsung Music and set it up as it was the first launch. After that, every album art will be correct, just make sure to not have any of the same album tags for different albums :)
CorpusChristi367
