Mute phone calls not working
sstephen17
305
I've enabled "Mute phone alerts & calls" under settings. It works on disabling notification sounds but calls still go through. Any suggestions?
My understanding is that the Mute Phone Alerts & Calls option just turns off the notification sounds on the phone (since the watch should be notifying you as well). Therefore, when connected, if you get a phone call, the phone itself won't ring, since the watch is already either ringing or vibrating. It doesn't have anything to do with blocking calls themselves.
Hmm, that is odd. I've never tried that function myself ...
That's what I thought but my phone still rings even when this is enabled. Strange.
I'm having the same problem with the watch I received today. I'm getting an update, though, so I'm hoping that fixes this problem.
vickyy
