A Android Central Question Oct 16, 2017 #1 My 7 edge won t recognize my memory stick it dose the 8 GB but not 32 gb why
B. Diddy Senior Ambassador Moderator Mar 9, 2012 167,957 8,313 113 Oct 16, 2017 #2 Welcome to Android Central! Are you talking about SD cards or flash drives? If the latter, are you using an OTG adapter, or do these flash drives have OTG built-in?
S sparksd Well-known member Aug 20, 2010 1,098 9 38 Oct 16, 2017 #3 How is the 32GB stick formatted? If NTFS, it won't work unless you use an app like Total Commander.
