My audio on youtube automatically decreases by 20% and I have to keep putting it at full volume
Hashan15
7
Is there a setting I can undo on my Samsung galaxy FE S21. I find it annoying to keep increasing the volume after a while.
Welcome to Android Central! Is this only when using earphones, or also when using the main speaker?
Make sure no power saving mode on if ok go to settings>general management>reset>reset settings
Omg yes ... under volume, the cursor was set at 80%, the exact limit it tends to go back to. I moved the cursor to the far right and hope it fixes it :)
I thank you profusely because it was an annoying device quirk. I do hope that one day when you face something annoying, that it is fixed through the kindness of a stranger just like how you helped me :)
Ok hopefully thats all it was
I don t have a Samsung but I found this.
Go to settings > sound and vibration > volume > tap the dots in the top right corner > tap on media volume limit > and make sure the media volume limit is set to off
The same issue persists. Media volume limit was set to off. Volume was at 80%, I moved cursor to max right side. I think I'll take it to android service center. Its still covered by warranty
Can you try safe mode ? Maybe some 3rd party app causing this
r3dpuk3
