My battery heats up( S note 9)
  • Start date Start date
A
Android Central Question
I purchased my Samsung Note 9 ,5-6 days back which was having a heating problem + the battery was draining very fast..So the service centre replaced the N9 with a new one...Now the battery seems OK but still facing the battery heating issue even if i use it continously for half hr( just browsing ).Is there any with the same issue...planning to go to the service centre again.
It might just be the heat pipe. If you're facing the screen it's on the left side and runs up and down most of the phone.
DannaOgle83
