My existing battery rating is different it is working fine or not ?
  • Start date Start date
A
Android Central Question
My existing battery rating is 3500mah 3.8Volts and my new battery is 3100mah 4.3Volt it is working fine or not ?
Which phone? Where did you get the new battery? Is it the same brand as the original?
If you need additional help or have more questions or details to share, please join the site so you can reply in this thread. See this link for instructions on how to join Android Central.
3.8 Volts is the nominal voltage of a lithium battery, 4.3 Volts is the fully charged voltage. The difference is in the mAh rating, and 3100 will mean less time between charges than 3500. (It's only about 12%, but it's different.) As djrakowski asked, where did you get it? Is it an original battery or a cheap knockoff (that may not be even 3100 mAh)?
KidColoringPage
