My Galaxy Note Edge SM-N915G firmware upgrade encountered an issue, Kies is not working. How can I fix this?
  • Start date Start date
A
AC Question
Galaxy Note Edge SM-N915G firmware upgrade encountered an issue. Kies not working.
Sir Please help me. yesterday i bought a Galaxy Note Edge SM-N915G in India and today i tried to root my Galaxy Note Edge SM-N915G using Odin 3.07 and CF Auto Root file (CF-Auto-Root-tblte-tbltedt-smn915g.tar) with proper way but It was unsuccessfull and not i am getting a message "firmware upgrade encountered an issue. please select recovery mode in kies and try again"
sir now my device is only able to go in downloading mobe but it is unable to go in recovery mode. i remembered that i did a mistake that i have not checked the USB debugging under developer option. i also tried for emergency recovery through Kies3 but kies3 is not detecting my Note Edge. now i am helpless....plzzz help me.
Happened this same problem with me the solution is you remove the battery and then press power key and volume button down and home button together and then rode the battery will enter into the downloading mode and by odin program based process remaining and you should download the official rom for your device you may do so through the site sammobile.com
Amazing sir thanx a lot......tried to flash stock rom through odin and it worked.....woooow....thanx a lot
Mike D
